chain thing: possible. Chain drop was an issue as well.
and yes – would be a strange crack.
But interested in the outcome…
If the crack was growing from the inside out – the crack might run “in line” with machining features. Cracks like to start at edges / corners / threads.
And directly “under” this mark there are a lot of features which cracks like to start…
Additional it needs a “changing load peak”. It’s there as well…
Never seen a frame crack there either
me too. But this is interesting.
creaking alot in the area of the BB for a while
mmmmhhh
not typical for a crack moving from the inside out: such a crack would be hardly visible.
Here it appears like the crack is wider to the top. Would reinforce the chain theory.
I would say 50/50
