What are the chainrings and the chain? There’s a problem with compatability here. Middleburn rings tend to be on the wide, chunky side, so prone to not “letting go” of the chain. Rings should all work 8 or 9 speed (guess you’re running 9 speed?), so 9 speed chain should be fine; double check you’ve not got a 10 speed chain by mistake! My first action would be to try a different brand of chain,and if that fails, go for some different rings, TA, as someone else mentioned, are very good. Cheaper option would be BBB, not a well known name, but great product for the money. Give it a few more rides first though, it may settle down. New CNCd rings can have very sharp square edges which take a while to mellow out. Good luck!
