My opinions…
TALAS was never quite right. Pandering after the spring crowd 😉 The Linear Part means it needs a lot more Low Speed compression for set up and good high speed R2C2 is the only damper worth it for TALAS. The Float is a lot better, especially if you never use the travel adjust.
As Onzadog has said a float conversion (replace the Talas part with a simple air spring would by my first move. After that if you want more set up then Avalanche. It gets a bit pricy as your paying in USD and it’s going to be hit for import. Fitting however is easy so long as you can do a lowers service and read/follow instructions.
