I'll start - 28lbs
I'll start - 28lbs
6" rear but 5.5" front
30lbs on the nose.
your scales need to be checked.
OK I'm 10mm short on the 6" travel, but what the hell, who's gonna start a 140mm travel thread...
28lbs
me too on the 140mm 27lbs, and i thought we all had to use kg cause of the eu??
Never weighed it, but very confident that it's under 30lb...
As usual, lots of pointless optimism and inaccurate scales going on here. The only way to acrape under 30lbs for a 5.5" (140mm) or 6" travel is to spend £4000+ on something with a carbon frame, full XTR, Chris King etc, and superlight inappropriate tyres.
I duno, my hardtail's under 30lb (expensive scales say 29.45 with pedals and mud)
And thats not built with anything lightweight (6lb frame, XC's/321's, magura menja's, then the rest is mainly cheep/indestructable stuff)
So getting £2k+ of full susser with similar intentions under 30lb should be a walk in the park!
And next years giant reign-X is sub 30lb (if you have the cash for the XTR build)
Giant's "light metal" alu frames are lighter than their carbon ones, I believe.
Dunno why you would get a 6" travel bike then spoil it by putting on silly light tyres etc to keep it under 30lbs. If you are a weight weenie why did you buy a 6" travel all-mountain bike?
Um, no. Five Pros are 28.5lb off the peg WITH pedals. Mine's 29.5lb on a digital fishing scales but it built up a fair bit from normal Pro spec. YES that's a 2.35 tyre on the front too and a 15QR vanilla!
(Yes the steerer has been cut now)
What, all sizes?
Well no but 18" - so hardly a small - but that's with 2.4 Mountain Kings which I don't feel are up to the job, hence the change on mine.
I'm quite amused at the calls for bullshit on sub 30lb 140mm bikes - we had a thread the other day full of supposed 25lb ones!
Surely every genre of bike deserves to be as light as possible - budget allowing. IMHO weight always matters. All mountain bikes do go up as well as down you know
I do wonder what the point of having an XTR mech on a 6" trail bike is. I've got one fitted as OEM on my bike, it's already been twatted with a rock and I've only owned the bike for a couple of weeks.
However I do agree that this is a very valid question
Unless you're made of money I wonder at the sense of fitting an XTR/X0 rear mech to any bike
stilltortoise, absolutely, unless you're racing, it's just an expensive way of showing that you've got money to burn. Fortunately my mech is still intact, and it's only the hanger that was screwed.
I'm a convert to SLX for the rear mech. I got one cheapish (£35 I think) so not a total disaster if it gets pranged, which I tend to do a lot with rear mechs. CLumsy, me
Not necessarily, some of us were lucky to bag our XTR and Dura Ace kit in the the days of cheap OEM in 2007.
140mm - 25.3lb
Frame size can make up to a pound difference between the smallest and largest sizes.
as can dodgy fishning weighing scales from Aldi
My Whyte 46 is 28.5lb according to them, but do I believe it?? Nope
Test them with a known volume of water. You'll have to make an allowance for the container, but you'll know how far out they are. I have a set of cheapo digital luggage scales. I calibrate them with one litre of water, 5 litres of water and 25litres of water. They only have a resolution of 20g, but they're perfectly on the money.
They make my 19" 5spot 29.4lbs and I do believe it.
But with non-superlight inappropriate tyres. Not sure on weight, but it's got to be under 30lbs.
No photo but I've also got a Five that comes in at under 30lbs. It's a custom Alp proof build with only reliable kit on it (XT, Tech M4's, Van 32's, XM719's etc) and it's still heavier than my mates Remedy which has Talas 36's bolted to the front!
It's a myth that a mid travel bike needs to be overly expensive to be a decent weight and strong these days.
tree-magnet, how much did all that cost?
Chumba VF2, 5.5" travel
My Ibis with coil pikes and very heavy D321 wheels is 30lb, a change to some decent wheels and air Lyriks should see 28lb.
28.5lbs in large. Noticibly lighter than the Meta it's just replaced, probably down to the wheels more than anything.
Around 28 - 30lb
Maverick sc's on the front now, not quite 6" f&r but 26.6lbs
WTF... 'course a 6 inch bike can be under 30lb. I weighed my Reign on a mate's Park digi scale at the weekend. I expected it to be 35lb plus but it is 32lb. And that's with a set of 'zocchi All Mountains on it. with a set of lighter forks and a very small sprinkling of bling it could easily be way under 30lb without costing a fortune.
Conversely my 'light' hardtail turned out to be 26lb. It has a light frame, light wheels and light forks. It feels very light to ride. Thus proving weight is more important in some areas than others...
Nearly every bike in here is 5.5" not 6" but I think a S-Works stumpy is pushing it completely bearing in mind the OP started us off with an Enduro...
My Pitch Comp weighed in at 32.5lbs on the shop Park scales my cheapo fleabay fishing scales measure about the same so I believe in them enough to say my bike currently weighs about 32lbs. If I swapped out the coil Pikes for some 2010 Revs with 150mm travel and put some 819s on it instead of the rubbish that it now has then it would almost certainly be under 30lbs.
A riding buddy has a 5AM with 36 Talas and a relatively tough build (as you would expect) and that comes in at 29.5lbs. Granted that cost nearly 3k but I could drop the weight of my pitch to that for less than 2k all in.
