I’ll be calling in the local firm for a service and a bit of troubleshooting on my central heating in the next week or so.
However, it’s always good to have some kind of background inkling of what’s going on beforehand.
Boiler kicks in fine for hot water, doesn’t do it for CH on its own, only when HW is running too. There are two motorised two port valves, and the obvious choice of fault is the heating valve, which makes a low hum but seems to do bugger all else when you select the CH.
Anyone had experience of this kind of thing – is it a straight swap out of the whole valve normally or a fettle to free it up?
Or have I missed something else? There have been some mysterious intermittent pressure drops at the boiler with no obvious leak or overflow to explain them.
