Geoff
You are talking about a mains pressure hot water cylinder, alternatively known as an unvented cylinder.
You need to make sure that you have adequate pressure and flow for this to work satisfactorily.
You can connect it to a boiler, or if you use a twin coil version then solar as well. You will not be able to connect it to a wood burner.
Mixer taps / showers will need to be suitable for high pressure and any showers should have a balanced cold water supply run to them from the cylinder.
If you have a suitable water supply in my opinion they are the best form of hot water supply. But as with everything there are is a big differnce between some of the units. From the bottom of the range Ariston units, up to the Heatrae Sadia Megaflows, or as my preferred unit an Oso.
i’ve not been around on the forum for a while but assume you can private message me for more information if you require.
