As long as you go for a stainless cylinder, over a vitreous enamal one, they're all much of a muchness really.
The various manufacturers will tell you their product is best because of x y y etc.
Have you checked your incoming mains pressure and flow rate? You definately need 1.5bar plus, ideally 2.5 plus. Flow rate needs to be 20 litres per min, minimum. Ideally 25 plus.
I've just qualified to fit these, got sick of paying plumbers to screw them up!
I usually charge around 300 quid, but it depends on a few things. An unvented cylinder needs a waste outlet, this can be the most difficult thing to get right.
It also needs wiring in properly, which I get a sparky mate to do. 9 times out of 10, he needs to re wire the heating controls as they are not done correctly.
I'm in the manchester area if you want me to take a look. I can also get hold of the cylinders at a fairly decent discount too
