Is the water any hotter than normal though ?
If you haven’t already, it would be worth draining and re filling the cylinder as this need to be done from time to time to re establish the air gap.
Found this to save me typing it all out 🙂
Turn off CW supply.
Open lowest hot tap
Hold open the red (usually) topped (Pressure and temperature relief)valve on the side of the tank by turning it – you may get it to stay open, or you hold on for an eternity until the hot tap stops flowing. Could be 15 mins or so
(Let) close the red topped valve.
Shut hot tap.
Open mains supply.
Wait till filling noise stops.
Open that same hot tap – it will sputter a lot as the air comes out.
