Hello, I’m hoping there are some inventive types on here who can help me get my Subaru Legacy through its MOT!
I’ve lost both front headlight washer covers from the car and this means that the washers no longer direct water onto the headlights. I think I’m right in thinking this is a MOT failure for a car with HID lights.
The headlights now look like this:
The mechanism still pops out when you use it, but water just comes straight out of the rectangular hole. There should be some sort of plug there that directs the water back to the spray nozzles and also attaches the chrome look covers.
I’ve found nothing helpful on Subaru forums other than Subaru prices, and it looks like they will want just shy of £90 each side for the parts 😥
I’ve tried making a couple of different plugs myself, but even secured with small zip ties the pressure is too strong.
The part for £30 odd quid doesn’t include the cap for the water jet unfortunately. I know because I bought one hoping it would solve the problem.
All I need to do is plug it somehow, but it needs to be a strong plug! Is sugru waterproof and will it adhere to ABS plastic? I’m assuming that’s what the water jet is made of.
T-piece and tubing from halfords, split it off the window washer, run it down the wing and tape it on to the top of the light. I had to do this to get my jap Legacy through the MOT here in N.I which is more stringent than England Scotland or Wales.
Mine was fairly easy, firstly unplug the motor for the light washers (as in the electrical plug), then it’s really up to you what to remove. I had to pop the bumper off to remove the old washers on mine, so ripped out the majority of the hoses from there back to around the wheel arch area then just tidied up what was left.
Nothing to do with an unwary tester, the rules are clear that they washers must be working if present. 4 different testers passed mine without a single advisory
VOSA’s states: “A car with HID lights MAY also have headlight washers and self levelling which must be checked and in working order if fitted.”
I had/have Hid’s (full beam/dip) on my MK2 golf with no washer/self levelling system and it never failed an mot, it does have horrendously expensive custom ground headlamp glass to properly focus the beam pattern though (before anyone pips in with with complaints regarding illegal hid beam pattern/blinding other road users etc – #1 for life applies here – don’t be a dick)
Well thank you to all those who suggested sugru, particularly mechanicaldope who got in there first.
It’s done the job of blocking the hole perfectly so far and the washers work as they should. Just need to see if it lasts long term.
Unfortunately the MOT won’t be passed just yet though as I’ve now got a non functioning wing mirror indicator! It’s been hit by something by the looks of it and the LEDs that are not broken are now dim and only work intermittently. Second hand unit ordered as about £500 from Subaru lol.
