good god. im glad some of you lot dont work for me.
chilli flakes? marmite? peas?wholegrain mustard. In a cottage pie. tut tut tut. you lot have been watching to much telly.
cottage pie, shepherds pie, beef and lamb, urban myth, both separated by nearly 100 years.
Originally it was a peasant dish, to use up left over roast meat,(Any meat). to stop it from burning when reheated the dish was lined with mashed potato,and then topped with a mashed potato crust.
MR Antoine-Augustin Parmentier is probably one of the people responsible for this dish, as he spent a lot of his time promoting potatoes as an edible food sauce to the poor,( this is where the assumption of the name cottage pie came from, as these people were mainly urban farmers/cottage owners.
Hachis Parmentier as it is known in our restaurant,(named after Antoine-Augustin Parmentier) does not contain any of the above whacky ingredients. i think those are personal touches which will only complicate a dish your not familiar with.
May i suggest you start with
good beef dripping.(high heat will not burn and gives a clean taste)
beef (again best you can afford.)
onion (french)
Carrot
Celery
Red wine.
good beef stock
And maybe a little tomato puree ( optional )
flour.
Butter.
Fry mince in hot oil until brown.
tip meat into sieve and catch oil underneath in a clean pan.
put this oil back into the pan the meat came from minus the meat.
put pan back on heat, when hot, fry onion, carrot,celery until brown.
Put the mince back in its original pan with the veg you have just cooked bring back up to heat.
Now tip your red wine into this hot pan,and decant all the sediment off the bottom.
When the wine has almost vanished, add your warmed beef stock, and put on a gentle simmer for as long as you’ve got.
Mix the butter and the flour together in equal quantities.(cold do not melt the butter)
When the mince is cooked and your happy with the amount of liquid you have, adjust the seasoning.
Gradually add the butter and flour mix untill it starts to thicken and develop a nice shine.
Place this mix in the dish you intend to put in the oven, and chill.( the dish not you)
Whilst mix is chilling
Peel, wash and cook some spuds in salted water. ( start spuds off in cold water)
When cooked, drain and return pan off spuds back to heat, give them a good shake, and evaporate the remaining water on a low heat.
Mash add s+p butter and a little full fat milk.
Whip your meat out and top with the mash.
Place in a hot oven 200 deg for 15mins.
After 15 mins turn oven down to 165 180 and cook for 30 mins.
At this point remove from oven and cheese.
Put back in oven until nice and golden ( or to save time place under a hot grill)
I charge £11 a portion for this dish served with seasonal veg, and today we sold 23 portions out of 90 diners.
Thats a lot of money on cottage pie.
sometimes the best things in life are simple, When done right.
en-joi
MB
