Ye-es…
RAID is a good idea, but it’s not a substitute for a proper backup scheme. (RAID won’t protect you if the building burns down, you’re burgled, the controller mangles the data, a user deletes everything by accident…)
RAID gives you redundancy and availability, so if a disk fails it minimises downtime and admin overheads. Ask yourself, “can I cope if the disk fails catastrophically in the middle of the day”? If the answer is no, you need RAID in addition to your backups. If yes (which is possible, if the data is non-critical, merely a backup itself, or otherwise offline data) then you perhaps don’t, but for the price it’s probably still worth considering in a business environment.
Disks can and do fail, sometimes suddenly (and professional data recovery is really expensive). Also, as the person implementing Something New, are you going to look like an idiot when it curls up its toes?
