1. Steerer too close to top of stem and touching top cap – you have ruled this out.
Yep, thats not the problem
2. Loose break calliper.
This is not the problem
3. Headset rebuilt incorrectly, missing an internal washer.
All parts are present and correct, according to the hope tech specs. I’m using 2 shims between the top cap and the split race.
4. Bearings not fully seated before stem tightened, leading to play.
Seemed seated ok to me,but this could explain it. Are there any techniques required to ensure the bearings are seated correctly? Have taken it apart many times now, all looks ok.
The bearings themselves seem to be ok, ie they spin smoothly and freely, the lower bearing does have some play between the inner and outer race , but not sure if this is just normal.
Anyone know the exact specs of the hope bearings, so I can see if I can find a cheaper source than the £15 per bearing I’m seeing on the usual bike websites.
