Viewing 10 posts - 1 through 10 (of 10 total)
  • Plastic ‘tubing’ to cover gear inner cables
  • NWAlpsJeyerakaBoz
    What im after is the thin plastic tubing you can get that covers the exposed gear inner cables on a frame that doesnt run full cable outers.
    Done a quick google search but cant find anything, anybody got a link to where i get get it?
    crispybacon
    this might do the trick although you do get some extra bits too….
    ferrules long
    NWAlpsJeyerakaBoz
    Cheers for the link CB, ideally though i’d like a long section of tubing to go between the two cable stops on the top tube.
    oneoneoneone
    heat shrink??? that comes in a small size
    oneoneoneone
    stoney
    I have a coil of it spare if you want… Mail me as i could`nt find yours.
    castone@btinternet.com
    NWAlpsJeyerakaBoz
    Cheers lads
    stoney – YGM
    Gephaudio
    Try this site.
    http://www.altecweb.com/home.asp?cat=Subcategory4200
    I have being looking on the web as I think earmould tubing used with hearing instruments would work (don’t ask how I know). You can get 30m for £9-£20 GBP. 🙂
    thisisnotaspoon
    i just “borrowed” some ptfe tubing form work, we bought it in for about £7 a meeter but it came in 10m rolls even though e needed about 3ft of it 🙂
    fill it with greese and cable tie the ends tight arround soe shimano log ferludes, and say hello to maintenance free gear cables 🙂
The topic ‘Plastic ‘tubing’ to cover gear inner cables’ is closed to new replies.
