Anybody use them. My youngster keeps catching his shins on the pedals when practicing his tricks! Ok on rides as he pads up but wonder if plastic pedals would do the trick.
I have plastic pedals on my unis. Grip is fine, even in the wet – I’ve never noticed an issue with slipping at all (though to be fair I don’t have much to compare them with). They’re still capable of making a mess of your shins though – if not quite as bad as metal pins.
Most of these cuts were made with plastic pedals. The ones at the bottom of the leg were made by metal pins which I then took off – they were a bit deeper than the ones made by the plastic pedals, but didn’t hurt any more, and a couple of months later I can’t tell the difference from the scars.
I’ve used Odyssey Twisted PC pedals now for a few years and find them fine in the wet, dry, mud, whatever – you need soft soled shoes for them to do the best job though. Sure they wear down after a while but at less than £20 a pair (and look at all the lovely colours 8) ) that’s not a major problem.
I agree, those socks clearly have threads starting to work loose.
As for plastic pedals, I have some lovely Primo ones on my BMX and also on my fixie. The pins are not too sharp but they are plenty grippy. Do 5:10 do junior sizes?…
Those are what I have on the unis – used by a lot of uni riders. Given that if your feet slip when riding a uni you tend to fall off, grip is quite an important thing. You can get them for ~£12 if you shop around.
Self abuse from practicing jumpy stuff on a unicycle. I now have shin pads.
