Right, what’s the best option for this?
Along the side of our house is a single skin section comprising 3 v small rooms. Flakey paint on outer walls and something like latex screed (done roughlay) makes it pretty much a storage space at present. Want to make it more usable and presentable. Plus warm to use 10 months of the year.
Two plasterers have come round and said they would quickly rub down the walls then dot and dab 27mm standard board (with 12mm foam back) all round.
My concern is the boards won’t take unless walls are perfectly prepped, thus in 3 yrs we’ll start seeing issues.
Don’t want the cost of celotex nor the additional space it requires. Am happy to run thermal lining paper over the plastered outer walls and then add a single rad. Will also add another layer of latex and then some kind of flooring.
What would you recommend?
Cheers all
