Basically I think a service for £100 is abit steep.
Any recommendations based on experience etc?
Loco?
but I just go to Dale at Sherwood Pines Cycles - £60/65 for shock or fork
http://www.pedals-edinburgh.com/
no complaints here - just got my floats back after a service and travel reduction
Drop me a mail with what needs doing and I can quote you.
All I do is suspension and nothing else, so the workshop is specifically setup for dealing supension units with all the correct tools and best quality fluids, seals e.t.c
The forks only cost me £350. Seems daft to spend £100 servicing them.
Loco- It'd still come out around £100 when you throw in postage both ways.
Do it yourself for about £60 (seals, washers, cleaners, oils/lubricants, tools). It'll be cheaper in future because you'll have the tools and the oils left over.
I tried
If you need parts give me a shout
I did this last Friday and overfilled the damper thus meant me having to compensate but dropping the air psi. Im sure in part it led to me flipping over the bars onto my knee!
I'm reasonably intelligent however I have zero patience.
Set up your own LBS in your living room so you don't have to travel 20yds to the nearest one, get a competent mechanic at minimum wage, then charge yourself less than the time it would take said mechanic to do the work, thus losing yourself money but hey you'd be able to have a good chat with yourself and make yourself a cup of tea and you'd lock up at the end of the night being one more satisfied customer because you run such an honest and great LBS!
Bosh!
Kit, I need more working capital from you.
We aint taking over the world with £10.
Uuugh? Do what? Are you saying you got the forks cheap but service them will no longer make them a bargain?
Yet you expect a decent life expectancy & performance from them 2nd hand without a service?
Mods please change of title please "Hora living up to his STW rep."
(I'm reasonably intelligent)
So your saying £100 for a general service is cheap?
We aint even talking adding in bushing costs either.
Suddenly the reason becomes clear for paying qualified persons to do something for you. Not all costs can be quantified.
(assume you post is to mine) Nope, but if when I buy 2nd hand I take into account that they might need servicing, and so the price I am willing to pay reflects this. So if push does come to shove, my bargain is still a bargain...
Got my forks and rear shock serviced from the bike chain just before christmas, can't remember what I paid but I was pleasantly surprised with the bill.
Learn how to do it properly and you'll be able to spend £450 on your forks next time. Muppet!
Madness. How people into mountain biking have a 'no fear' approach to big bills.
Would you see this mentality in the roadie world?!
Just a note the Evans rear shock 'service' is an air can service and seals only.
I fear no pelican.
Maybe if you bought new, planned to keep stuff for a while and factored £100/year running costs in it wouldn;t seem so expensive?
http://www.chippingcycles.webs.com/
Any help?
I fear no pelican.
Like the numerous new Rockshox forks I had break on me?
You are right. Spend alittle extra time on them and sort them myself. I ended up rushing the oil refill on them as I couldn't find the funnel and ended up over-topping the night before the ride.
£100 I'd rather pay myself to do that for circa 40mins work. Plus I've got the spare wiper and seals kit already that came with the forks from the lad who only owned them for less than a month.
yes the cheap deals on shocks just look like air can service to me
Use a big syringe, it more accurate, mail me and I'll send you one if you like (F.O.C of course)
edit, yes and the air seal kit is £9.49 plus postage, easy job that takes 10 mins.
Are instructions for fox services avalaible anywhere? I've got an shock and fork to do.
Knock yourself out...
http://service.foxracingshox.com/consumers/Content/index.htm
jonb:
there you go: http://service.foxracingshox.com/consumers/index.htm
Edit: damn you and your Fish
Loco - you refer to Evans as air can only - what do I get for my £55 off you? I've never even tried servicing any suspension so have no idea but my RP23 could do with some tlc
Yoshi:
That's a full strip, clean, inspection and rectification of any manufacturing defects. All seals in the damper are replaced and the unit has the oil and gas replaced. The air seals are also replaced as are the eyelet bushes. If spacer are needed they would be a little extra.
I don't like replacing stuff just for the sake of it, if they're going to last another 12 months then why should you have to pay for it.
Postage back is extra
My money is that hora didn't empty the damper fully, and this has put the total oil level too high. Schoolboy error.
http://www.flotecsuspension.co.uk/home.aspx
Fairly new company, but good!
Bike treks are running fox servicing courses,i'm booked on the 20th of feb
Flotec, are charging for a clean, oil change and greasing the seals, wipers are extra.
If people are interested I'd be happy to do an evening course on servicing of forks.
