I bought an iroko frame from evans last year and have only just got around to putting a dropper on it.
It has holes drilled for internal routing including the dropper but I’m sure there must be a guide or suchlike – it’s just a hole. I’ve tried searching for a generic part but nothing seems to fit, tried contacting Evans but they never come back to me. I think the higher Iroko’s have droppers so if anyone has one can they tell me if there is a guide for them or not? Maybe you just run the cable through but I’m worried it will move around.
Here’s a pic (it’s the circular hole in case it’s not obvious, other has gear cables running through for rear mech)
Hi – what did you end up doing with this as I tried to run the cable through my iroko frame and it’s a bit of a nightmare the bends needed in the cable seem quite extreme?
