Well the usual rather cringe-worth marketing stuff:
The short version is that its sturdy mono-stay swingarm telescopes on a tubular aluminum stanchion, which, in conjunction with a rocker link control arm, provides a measured amount of anti-squat action throughout the bike’s suspension travel…
Just like every other suspension design then.
Cunning, just throw in a reference to “gear range” there. Not actually saying that it works the same in every gear, because it won’t. The axle path is fixed so it will suffer from changes in pedal interaction as the gear changes just like other designs do.
The telescoping action works to balance the suspension’s anti-squat function against the rider’s mass close to equilibrium…
Nope, can’t make this make any sense however I read it. The telescope is a necessary suspension component – without it, the bike would collapse.
… which frees the system to react to the terrain without the need for excessive damping or spring force.
I guess the bizarre claim about the damping may have something to do with some damping effect from the telescopic pillar (or “stanchion” as that review calls it). There’s going to be some side-loads going through that.
Well a translation would be nice, but isn’t provided.
