My pikes have started sucking down into their travel, they currently sit at 15-20% sag with no weight on the bike.
Had a search and found threads mentioning cleaning out the port between positive and negative air chambers.
I took the lowers off and noticed the air spring is sucked into the uppers. In all the videos I’ve seen the air spring gets pushed in by hand while removing the circlip.
I removed the circlip and managed to get the air spring out, but there was a pop as air released (stuck in the negative chamber I guess?).
I gave everything a clean and put it back together. Pumped back up and got all my travel back, forks feeling plush again.
This only lasted for 5 mins before sucking back down into it’s travel.
Had another search and found a few posts about a hidden schrader valve somewhere in the air spring that may be blocked / faulty. Is it worth trying out a new air spring, or should I just send them off for a service?
