I amazed by the low pressures people are quoting. Im 85kg, 2 tokens, 90psi, 160mm. Alternatively on my 120mm pikes, im 4 tokens and 110psi.
Forks feel good, ie in rough stuff the chassis is stable without too much feedback through the bars, also stiff enough to really weight the front wheel in turns but not so much so the front wheel doesn’t track the ground.
Are we on about feeling too stiff when you stand over the bike and compress the forks?
Is this a case of what you think good forks feel like doesn’t necessarily correlate to what good forks feel like?
