I’ve ended up here: 25% sag + 2 tokens (60psi), LSC 7 clicks, Rebound 5 clicks.
Started out with no tokens, then one, then two, then one, then two. Sag has varied between 20% & 30%. Have had rebound slower and less low speed compression. The final setting seems to give the cornering grip I want and the right fore-aft balance when jumping – the extra low speed compression lets me preload harder as does the extra token, whilst the relatively low pressure keeps the front tyre tracking for good grip.
I think the extra spring progression means you can run less rebound damping because the rebound effectively slows down as the forks extend, so you get a good amount of pop when you push hard for takeoffs but you don’t get that annoying understeery push from the front trying to unload mid corner.
