Done full service on RS forks a number of times now and easy enough. However not done a Charger before.
I’ve still got plenty of the regular oil from TF Tuned. Their stock lower lube mix, and 5wt oil. I notice they supply this in the refresh kits for Pike 2014+.
On bleeding the thing, I’ve got various syringes inc the bleed kit for Reverb. Cleaned out, can I just use the same syringes with the Charger along with TF’s 5wt oil? RS manual says 3wt.
Lowers, RS spec 0w-30, but TF just seem to have a generic lower lube mix for most models inc Pikes.
Also, I see there’s a bleed connector sold for the Charger. Would I need this or would the Reverb bleed connector work?
