1) Burp fork by placing a very small zip tyre between the seals and the stanchions. Most air moto forks have bleed valves for precisely this kind of crap – **** knows why MTB manufacturers can’t see the value in them.
2) Tear fork apart, remove grease from port that equalises the pressure between the positive and negative air chambers. Rock Shox in their infinite wisdom like to pack a crap load of grease into their forks, too much! The ports design is flawed so the only way to rectify it is to use less grease or another type of lube.
It’s a very common issue and one that is causing me to consider a coil conversion from CRconception in France.
Oh yes, and welcome to one of many idiotic Sram designs – next, your maxles will unwind themselves and your wheels will fall off halfway down a downhill run.
