Have had my Pikes for a month (140mm on a 29er trail HT). Despite the cost they’re a superb value upgrade over the previous 120mm Rebas. My backyard is Surrey Hills.
I find I’m using the modes like this ..
Open: moderate plus descents where taking a lot of hits (example The Wall), and most off road seated climbing where I find the front drops a little and they soak up all the trailcrap well. I’ve not messed with the Low Speed Compression setting yet.
Pedal: bermy or smoother trails where I want a bit of support rather than to be pushing through the travel, think for instance the Holmbury Hill classics ParkLife and Golden Birdies (AKA some silly new names). (for the more rooty trails the jury is still out between open and pedal).
Lock: road I guess or perhaps out of the saddle and working it on climbs. Don’t use it much.
Currently at 70psi with rider weight around 80kg (yeah I know the guide says higher) with rebound about 6 clicks off max.
Anyone care agree/disagree/correct the above? I am no suspension guru, here to learn.
