Hi Tom, No, I am a big fat lad at around 14.5 stone.
Unfortunately I don’t know how many clicks I am using. I tend to just set up on feel, bouncing around on the patio, then tweak again if needed once I am up the woods.
Bigjim makes a good point. I read somewhere that when you set the pressure you should cycle the fork through its travel up to 10 times to allow the air pressure to balance out in the fork, in both positive and negative chambers (I think, stop me if I am waffling). I did find that this had an effect and make sure I do this if I tweak the pressure before measuring the sag again.
