I know we see this Pike v Yari question come up now and again, I think mostly because the Pike is often discounted to near Yari money and the Lyrikl isn’t.
Really though the discounted price comparison is the only similar thing about them.
Really the question is do you want an Enduro / Park fork, or a Trail fork? Once you’ve decided which is best for your riding – how much do you want to spend to get the best damper for your needs?
If it’s a Trail fork you want a Pike, if you can’t spend enough for the RTC3 version, then seek out a OE Market RC version, it comes with the same adjustments as the Yari, which to give it it’s full name is a Yari RC.
If it’s a stiffer, but heavier fork (with a larger negative air volume) then you want a Lyrik or a Yari – yes the Yari has an older, simpler damper to achieve it’s RC status, but it’s still a good fork and has some benefits – mostly that It’s complete childs play to service yourself.
I have a Yari and a luftkappe (very good they are too BTW) but I read people saying “Yari with a luftkappe is as good as a Pike” which is not really true, they’re meant to do slightly different jobs and whilst they’re both RS and black, they’re not the same, they don’t even look that alike side-by-side.
