Viewing 18 posts - 1 through 18 (of 18 total)
  • ******* ****** piece of **** ******* laptop.
  • bearnecessities
    3 hours of work, binned.
    chojin
    Three hours and you didn’t press the save button once?!
    Jamie
    Surely 2 hours with the clocks going back?
    Unless he was saving to the cloud, or an external, I don’t see how that would help if the HD is borked.
    …if it it’s just the case of Windows taking a shit over itself, then whip out the HD, pop it into a external caddy, and retrieve your docs using another computer.
    mikewsmith
    BSD doesn’t mean your hard disc is fried Jamie, BSD is a get out/explanation of whats wrong when it crashes.
    If you loose 3hrs of work then remember to save more often whatever your using.
    chojin
    That is *highly* unlikely that the hard disk has shat itself.
    It’ll be recoverable.
    Conqueror
    chojin
    Remove your USB smart card reader and reboot 🙂
    (Assuming it’s plugged in)
    Jamie
    I was assuming there were more issues than just blue screen pictured, as like you say the files would be recoverable, which means OP really didn’t save once in 3hrs*. Which is akin to popping your johnson in a hornet’s nest and expecting good things to happen.
    *No autosave either?
    bearnecessities
    I should have expected the “save more often” remark!
    I went for a brew and came back to discover that.
    However it’s back to life now and unusually (from my exp) Word actually managed to recover it from only ten mins ago. Yay!
    Edit: Yes, autosave set-up but previous exp is that autosave rarely presents me with autosaved docs whensomething goes borked.
    Anyhow, all well now
    chojin
    You’re welcome.
    Jamie
    So you went from 0-DRAMA! in a very short space of time?
    bearnecessities
    0-DRAMA-0 again 😀
    Thanks all 😳
    Chojin, how do you know I’ve a smartcard reader? (integral though).
    samuri
    what is the document?
    bearnecessities
    Word. Thinking about it, it’s excel I’ve had problems recovering previously.
    scottyjohn
    I keep all my docs on a Dropbox folder, then if hard drive goes t@ts up, nothing lost 🙂
    chojin
    bearnecessities – Member
    0-DRAMA-0 again
    Thanks all
    Because that’s the device/driver which caused your bluescreen.
    szccid.sys
    fasthaggis
    Mr bear
    Your threads rarely dissapoint..
    Now go and rope your house down, thars a storm acomin 🙂
    bearnecessities
    Ahhh, card reader has been temperamental lately. Ta.
    FH. I’m not biting 🙂
The topic ‘******* ****** piece of **** ******* laptop.’ is closed to new replies.
