Viewing 11 posts - 1 through 11 (of 11 total)
  • Phil Wood Philcentric Bottom Bracket
  • Kuco
    Anyone tried one or got experience of them?
    inbred853
    Bit pricey, not got one of those though. I’ve got a Forward Components EBB which is basically a similar design and used it on my Inbred with no slippage/ creaks.
    Kuco
    Are they still going inbred853? Tried to go onto their website but nothing.
    inbred853
    Kuco, not to sure, had a quick look via Google but the links go to a hosting site. I bought mine in 2009/10 and as I said worked well with my inbred with 16:32 gearing.
    I use it to single speed the inbred over the winter.
    druidh
    I have one.
    I used it briefly (9-10 rides) on my Fatbike in order to use an Alfine Hub. Despite being a bit put off by the fact that the initial lining-up is done by locking the shells in place with Loctite, it’s a system that seems to work.
    Be aware that the BB Shell is larger than a normal one and certain cranks won’t fit over it (I’m guessing old Deore would be a problem). Any SS crank – or one with a removeable inners spider should be fine.
    You need a set-up tool for the initial installation. I had to ask them to make one up for my Fatbike (100mm BB see) but it’ll work with smaller BBs too. Do remember to factor in the cost of the tool.
    Do you want to buy mine? Make me an offer.
    thepodge
    The PW one is a bit expensive & the Forward components site seems to be long gone, are there any other options?
    inbred853
    There was another type that I considered called the Ecentricker, very similar to the PW and FC above. Again a quick search on Google doesn’t throw up many links.
    Kuco
    Thanks for the offer druidh but at the moment just looking and toying with some ideas.
    inbred853
    Ah, found this, used the correct spelling this time!
    Ecentriker
    thepodge
    oof, still over 100 quid plus fitting tool
    nedrapier
    druidh, do you still have yours? Still looking to sell on?
    Could you ping me an email if you have and you are, please?
    edn8 at hotmail dot com
    Ta!
The topic ‘Phil Wood Philcentric Bottom Bracket’ is closed to new replies.
