After asking for window advice for a period property, I might as well admit my complete lack of any ideas and ask for paving / patio surfacing advice.
A bit of background … gound levels have risen over the years, in some places to ~50cm above floor levels; a bit of digging found the odd air brick 15cm below ground level! As the gropund level rose, people lobbed gravel on it, and when that got a bit untidy they added more. Eventually they decided to concrete over the whole lot, and when they decided that looked grotty they lobbed more gravel on top.
To get the stone walls properly renovated (lime pointing, lime render etc.) requires the ground levels to be sorted out, so I’ll have ~100 tonnes of assorted concrete and dirt to shift (plus a naff ornamental pond once the frogs have gone).
I’ll then have quite an area to be levelled correctly to take water run off, probably a french drain next to the house and quite a large area (think 2.5m wide footpath running 25m in an L shape) to be surfaced (and a new retaining wall to hold back the garden).
So, what would be a good paving? It needs to:
1. Look good & in keeping with a period house (so no fake slabs etc.)
2. Not be slippery or be likely to become slippery (in winter the sun doesn’t get round to the area but it’s a sun trap in summer)
All ideas gratefully received.
