to wiggles : why is it pointless or rather why is seatube length important when it comes to reach numebr? ok so if it has to be seatube must be short enough for 150 mm reverb so lets say 445-450ish ( shorter seatube is best – saves frame weight)
jam bo : i owned 4 full sussers and was experimenting with stem lenghts/ handlebar upsweep/backsweep and also height ( steerer spacers) many times on each frame , so somparing each frameset geo the numbers are bang on what i want – please note that I included some geometry tolerances that would be within my desired handlicg charasteristics of a frame with 50 mm stem.
benpinnick : yes you have valid point but in reality that does not matter. with that extra SA steepness I will be able to pedal uphills without need to bend my back/get my torso above stem – super comfort uphills + front wheel glued to steepest firetrack , but most importantly when standing and shredding downhills , saddle will be in perfect position – out of way when moving around bike/ getting behind saddle etc + added benefit of using saddle to steer with my thighs for better cornering (one of my previous framesets SA was 75 and it was excellent )
