andytherocketeer – Member
every pump i’ve used has been extensible enough to reach around
and of course the ones that hold things up, also are the ones that pump the last quids worth really slowly to pump an exact £xx.00 but then go and pay on card
I’ve found the occasional pump that wouldn’t stretch across the back of the car enough for the nozzle to actually go into the tank neck, on one occasion that caused a real problem, there was only one pump available, so I used that one, a diesel pump, and put £18-worth in.
The car was an Astra GTC. It stopped dead a couple of miles further on, because it was a petrol engine.
In my defence, I’d never driven one before, and the inside of the filler cover had a black label clearly marked ‘Diesel’!
If I’d been able to get the car to a pump on the correct side, and found the nozzle wouldn’t go into the hole, it would have raised a query, but with the bottom of the nozzle facing up, and pressing against the car body, hose stretched tight right across the bodywork, it ‘just’ touched the hole, allowing fuel to flow into the tank.
I try to get an exact amount into the tank of most cars I drive, because I only put in enough to get me to my destination, and when I pay by card, not only do I have a PIN, but I have to put in the car registration and the mileage of the car, so you’d be really pissed at me, then!
Actually, I take far less time than the commercial drivers filling up then stocking up on crisps, coffee, sandwiches, donuts, The Sun…
