Looking for a new desktop. Not for anything other than internet, office docs and photos/music storage.
Is there any noticable difference between intel and AMD processors ?
Thanks.
Thanks.
Not unless you're a geek
If you're asking then you don't need to worry about it.
intel have better performance at the high end but theres a premium for that, at the lower end i'd probably go for an AMD as you get better value.
+1 for disco_stu - if you're on a budget go for AMD.
AMDs seem to run MUCH hotter, meaning more fans and louder PCs, if that's important to you.
I see things haven't changed at all then in the last 9 years since I was a PC technician.
Well AMDs used to run much cooler (or at least they did back when I bought mine) mainly due to the AMD Cool'n'Quiet tech, but it seems Intel have turned the tables on that one fairly recently.
I have an AMD Phenom II x3 processor in my new build. It flys. £74 well spent.
For what you want to do with it, it won't make the blindest bit of difference which you go for!
