• This topic has 36 replies, 15 voices, and was last updated 15 years ago by wors.
Viewing 37 posts - 1 through 37 (of 37 total)
  • Peel Tower
  • wors
    over to Crowthorn School, do you actually pass through the shooting range?
    simondbarnes
    Yes
    wors
    How close? Is it safe?
    simondbarnes
    Completely safe if they’re not firing and if you don’t pick anything up 🙂
    There’s a number you can call to check if it’s open. This might help.
    twinklydave
    if there’s a red flag flying, then close enough to blow you up!
    if there’s no red flag you may just get some cadets running past you up the side of the hill (top tip: chasing them up the hill with a bike on your back is good training for the 3 peaks cyclocross…)
    wors
    Cheers for that.
    lowey
    Its just the Horseshoe shaped bit of Bridleway that they close. There are red flags where it enters the range if they are firing.
    samuri
    And there will be a soldier there to stop you if they’re firing.
    blackshaw
    whats a good ride that incorporates that track? looks to be a bit out on its own.
    ransos
    I grew up in Ramsbottom, and can assure you that there’ll be a big bloke with a gun to stop you on the bridleway if they are training. There’s a cheeky diversion I think, but I can’t really remember it well enough to describe.
    terrahawk
    I’ve seen the flags out quite often but I’ve never seen a squaddy with or without a gun.
    samuri
    diversion from the entwistle side is ride up the road and then take the left hand road fork where it turns to a farm track, that’ll take you above the barn and round the top of the moor. You drop back down to the track at the flag location at the opposite end. Bloody hard slog mind.
    blackshaw: Three towers would be the obvious answer…
    http://www.samuri.co.uk/gps/06032005.gif
    There you can see what happens when there’s a soldier stood there with a gun who tells you to bugger off. I couldn’t be bothered going up to the top of the moor so went round the road way.
    lowey
    The Four towers is a cracking ride. I’ll post up the route in a bit.
    simonfbarnes
    Completely safe … if you don’t pick anything up
    yeah those soldier lads have “easy virtue”, you never know what you might catch 🙁
    CHUCKMORR1S
    samuri – Member
    Do you cycle alot around this area?
    samuri
    Not for a while now. Used to though. Need to get back over there this year. Darwen is great because there’s so much open moorland and it’s invariably empty. It’s nice to drop down to Ramsbottom and from there pick up the Mary Townley loop and it’s offshoots.
    lowey
    The four towers
    Rivington Pike, Darwen Tower, Peel Tower and Turton Tower. Great day out.
    Obviously you would need to edit the route a little unless your setting of from my house 🙄
    blackshaw
    cheers samuri and lowey, looks like I’ll have to get a west yorkshire exit pass for a day!
    wors
    Where do you live lowey?
    big_n_daft
    Ther is a cheeky way to Hawkshaw from near the sentry point on the Crowthorne side.
    Range times are published on Bury MBC’s website
    I might try suggesting to the Army a permissive offroad diversion route for range days
    D0NK
    Sometimes you can get through even if the red flags are up, Last time I went there the flags were up and shots being fired but the squaddie on the path said I was ok for another hour or so before they closed it off, must have been shooting lower down. 3towers is a cracking ride but that section to peel is a there and bock or quite a bit of road (or cheek but I’ve not found a good cheeky route yet) but its good in both directions so thats ok 🙂
    big_n_daft
    seeing as there is only one range and one danger area you may have been badly advised. The only other possibility is that they were using blank rounds in another part of the area.
    If the red flag is flying I wouldn’t go in, if you get slotted you don’t have much recourse, i also wouldn’t assume that the bullets stop at the red flag, the danger area is based on a statistical analysis that takes into account the assumed angle of shot (at the target) and ricochets. The assumptions don’t take into account the ability of the firer to shoot straight, stray/ accidental shots etc anyone who has seen tracer will tell you bullets can go out of a danger area
    “crack and thump” will also tell you that you are in the wrong place
    MrSparkle
    The 4 Towers. As listed above but not actually the order we did ’em in. Happy days – remember Summer?!
    lowey
    It was a lot wetter last time we did it Simon, last March. we did it in the same order. Had a nice feed stop at the country cafe at Tockholes.
    Wors, we are in Sharples mate.
    wors
    lowey, me too! Just opposite sharples high school
    lowey
    Drop me a line if you ever fancy coming out with us. We mainly ride thursday nights (although this does end up in the Belmont Bull for 4 pints minimum then ride home) and Sundays around about 1pm. Pace is relaxed.
    wors
    Yeah will do, 4 pints! suppose it is all downhill from the Belmont Bull!
    lowey
    It was 6 last thursday!
    trio25
    I think I can cope with two pints and that’s it, I’m not hardcore enough for you guys! I live just a little further round the ring road, love rides ending in Belmont though as its downhill home!
    lowey
    Surprising how many posters turn out to be right on your doorstep lol.
    MrSparkle
    You knows it!
    How’s it going Lowey? ;0)
    lowey
    Not bad thanks mate.
    You still out beasting the single speed every week ?
    I still recount the story of you managing to make it up San Marino on a SS every time we struggle up the fooker.
    weester
    Lowey-‘(although this does end up in the Belmont Bull for 4 pints minimum then ride home)’
    Like he says though, the last time was 6 pints and I’ve still got the bruises to prove it!
    Your right though wors, it is all downhill except that short sharp killer of a climb up to San Marinos, complete with as of yet to warm up muscles. Fun tough.
    MrSparkle
    Lowey, I am just getting back into it after being out for pretty much 12 months after a bad knee injury. Not sure I am quite up to getting up that fooker without dabbing at the mo. ‘Specially after I saw how cut up it was when we came down it t’other week.
    trio25
    People ride up it?
    lowey
    It does make a good climb Trio, nice and steady with a few tech bits to keep it interesting. Surprising how quick you gain altitude on it.
    MrS …. sorry to hear that mate… what happened ?
    Your right about San Marino too, from top to bottom now its getting pretty technical and the ruts are potential killers. Makes it very interesting.
    wors
    I might come out for a ride next week, giving blood tonight so probably not the best thing to do tomorrow!
The topic ‘Peel Tower’ is closed to new replies.
