• This topic has 31 replies, 14 voices, and was last updated 9 years ago by Pook.
Viewing 32 posts - 1 through 32 (of 32 total)
  • A Peaks loop tomorrow
  • djflexure
    Headed over tomorrow for a pootle. I get over once in a blue moon; have mainly ridden the BWs around Ladybower, Hope Cross, Edale. Any suggestions for a 20-30 miler? I presume there has been a bit of rain, are there any areas to avoid? I have the VP book somewhere – will dig it out too.
    Pook
    Check out kofthep on twitter for conditions. There’s a wet weather loop been done too by vg if you look on the access pages of stw
    vg loop and kofthep stuff
    daveagiles
    Weather looks like it will be ok tomorrow, but the ground is very wet.
    The VP wet weather loop is a very good bet.
    BadlyWiredDog
    Whatever you do, do not go within 2000 metres of WLT or Podge will explode in a cloud of gritty wet slurry and dead sheep innards and that would be horrid.
    You can always check the Keeper of the Podge twitter feed to see how close he is to detonation btw.
    Pook
    Bwd – stop baiting and behave yourself!
    Podge has his hands very full at the moment. Derwent edge should be ok now though – they did some drainage work up there
    (I’ve not been up)
    BadlyWiredDog
    Waddya mean? I was simply and clearly explaining the potential consequences of riding in THE WRONG PLACE… the Edale-Hayfield loop via Jacobs and the Roych is probably a good bet btw mostly because it goes nowhere near the place in question the name of which shall not be mentioned.
    Pook
    You’re just being provocative. The wet weather loop’s a good one regardless.
    I reckon wlt needs some north shore 🙂
    BadlyWiredDog
    Ladybower needs a proper trail centre asap, but I don’t see why it shouldn’t incorporate some shore and maybe that pipe that crosses the reservoir near Fairholmes…
    Pook
    And a ski lift for the beast
    djflexure
    Cheers – I will take your advice and explore the wet weather loop. I can’t find it on VP site so if you have a GPS, my email is in profile – taking a liberty I know.
    WLT means nothing to me so I will inevitably get lost and end up axle deep. Apologies ‘Podge’ in advance.
    iforwilliams
    I’d be interested in seeing what the wet weather loop is like also. Is there a track file?
    dannyh
    I’ve just popped the kettle on, let’s see how this one escalates……
    The drainage cuts that have been dug on the Derwent Edge side of WLT looked to be doing their job last Saturday, the ones closer to the top seemed to be doing a bit better than those further down, but that is probably because there is a bit more of a drop off of the side there, so the water runs off quicker and won’t silt them up so much. Credit where credit is due, some people are getting out there and trying to keep the trails in as good a nick as possible. The other side of WLT was holding up last Saturday as I rode right down the middle (no mincing off into the heather, I promise). The surface itself was still firm. I doubt it will be now, though.
    The really boggy bit at cutthroat bridge was rideable by very moderately skilled types like me (not so many wheel swallowing bogs that there was only one possible permutation of line through the whole thing). Again I suspect that will not be case now.
    The wet weather loop is a good alternative.
    You could also do Ladybower avoiding most boggy bits if you avoid anything east of the reservoir, perhaps tacking a road and Jaggers Clough loop on instead of WLT.
    thepodge
    Someone called!
    If we’re discusing keeper of the Peak I’m more like Albert the butler than Clark Kent
    I still stand by my minimalistic wording and it’s intended, apposed to its triple secret message. I’m sure someone will be along soon aiming for a world record in angry long forum posts and another to tell us the entire peak is beyond saving.
    Glad the work we did up there is holding up and appreciated
    I’m off to change a nappy on my newborn, I wonder where I’ll find more crap, here or there?
    dannyh
    No secret meaning discernible there, although I’m not familiar with the word ‘apposed’. 😉
    Newborn? Not much crap, you wait until you start feeding them solids, then it takes on a whole new level of horror.
    Seriously, anyone who has the time to get ‘out there’ and try to improve things has my admiration. With two kids myself I basically just get to ride and remove the odd stick that’s been left there by the armed faction of the local red socks.
    SandCrab
    OP – I did a Jacobs Ladder loop that I downloaded from the MBR site, if that is any good.
    Chris
    hora
    OP in the VP book-I love the jacobs route and almost all rocky 🙂
    thepodge
    I could have gone riding, I would have preferred to go riding but I’m not permitted slaves so I have to keep my Kingdom in good nick myself
    djflexure
    Thanks to all
    Just settling down to look at the vp book now
    Pook
    It was good fun that dig
    hora
    The drainage on WLT looks good. Well done to rogerthecat the other non-local trailsman too.
    SimonR
    djflexure – link to the route on the VP website for you:
    http://www.v-publishing.co.uk/blog/v-publishing-blog/2014-01-20—free-download-kinder-all-weather-circuit.html
    It’s a great route in the dry too!
    scandal42
    This may well be a silly question but is there a similar ‘wet weather loop’ in the White Peaks?
    I imagine the geology of the area would make it less likely.
    benman
    The riding around Eyam and Longstone Edge is pretty rocky for the white peak and drains well.
    Some of the less techy stuff around grangemill, bonsall, birchover will also be quite rideable.
    These areas both feature in the VG White Peak book.
    Areas to avoid are Manners woods, Gratton Dale, North woods, Copy wood…
    Pook
    Did you have a good ride djflex?
    Also, just noticed keeper of the peak has gathered some wet white peak routes…. We’re being watched 8-0
    dannyh
    Careful now, you were only made an earl on the previous thread…….
    So it would be your earldom.
    cuckoo
    Whilst you’re on the subject of WLT came across the following in DCC’s 2014/5 plans for “Walking and Pedestrian Quality Networks (Investment Protocols IP51 and IP51a)”
    Bridleway 5 (Ladybower Reservoir to Cutthroat Bridge)i.e. the bridleway to/back WLT running through Ladybower Wood.
    ” Surface improvements and drainage to improve accessibility and to support sustainable tourism and leisure, improve health & well-being and increase resilience to climate change. Supports moorland restoration project.”
    Sounds ominous, anyone know anything about this?
    djflexure
    Had to take a raincheck, but it’s plugged into my Garmin for late next week. Ended up on cannock chase; long story but my wife took kids to Alton Towers and I did not want to leave our dog home alone. Thought the Peak would be suboptimal for dog due to the road sections.
    satchm00
    Probably best its been boggin all week, today was the first dry day.
    thepodge
    Peak district mtb know about the planned work and have been chatting nicely with the relevant people
    I’m not sure of the exact details but I’m happy to file that one in the “it’ll be fine” folder
    Pook
    Shut up podge you idiot
    thepodge
    Sorry, did you want to release that news in your glorified pamphlet?
    Pook
    I am just the Ted to your Ralph.
The topic ‘A Peaks loop tomorrow’ is closed to new replies.
