I have a Buffalo Linkstation NAS drive. And it’s stuck in “EM” mode. Basically, the only way of communicating with the drive is using the firmware flashing software. I need to re-flash the drive to get it working again.
I’ve been speaking to Buffalo tech and they siad to do the following:
“Attach the linkstation directly to a PC with a network cable, refresh the Nas Navigator and note the IP address, set a static IP address on the network card of the PC to match the IP address range the linkstation is on. Deactivate all anti virus and firewall software (including the Windows firewall) unzip the downloaded firmware and then run the LSUpdater.exe file.”
I’ve attached the drive, windows picks up the connection OK. but how the hell do I assign a static IP address to my network card in Vista? All I can do is to go into the connection properties, got to IPV4 properties and set the IP address as instructed, as well as the subnet mask.
Then windows gives and error message saying there is an IP conflict.
Any thoughts (apart from dismantling the drive and sticking the HD into a new caddy…)????
