Yeah I cable tie the two together. The gear cable is fine, just the brake hose. Will whip the caliper off tonight to see if I can persuade the hose to live closer to the chain stay.
This is the best I can do, the hose seems pretty close to the spokes/rotor when the bike is static but as the shock compresses the hose moves further away from both.
Ps I can only apologise for the patio/lawn/plastering in the loft.
That’s what mine looks like – cables are zipped together under the BB – no issues with it moving though – bigger ziptie on the chainstay as tight as possible to keep it tight?
Stopped the hose moving now with a bit of insulation tape on the hose at each cable stop so just wanted to check the clearance was normal. no matter how tight I had the cable tie previous to adding the insulation tape the hose moved but now it stays put.
A few upgrades, cranks, pedals and chainring along with a couple of other bits and the weight is down a bit. I’ve put another couple of hundred miles on it and still love it.
I resisted the temptation to go for shorter cranks and stuck with 175mm and I’m glad I did.
Still lacking in confidence but it is slowly coming back. Looking forward to frost free rides.
