How do you achieve pivoting through the centrepoint of the lense rather than the point where the camera attaches to the tripod? Are good compact cameras up to the job or should I save up for a compact system camera such as the canon EOS M? I enjoy photography and can use a camera in its manual settings but can’t justify the cost of digital SLR.
The proper way is a nodal point tripod head – I use a Nodal Ninja 3 – but for landscapes and especially if you’re not doing 360-degree panoramas you can get away with a normal tripod or even doing it handheld.
Would agree with that and do all my panoramics using a standard tripod head.
Make sure everything is in manual so the exposure doesn’t change for each shot. Set ISO, shutter speed and aperture. If you can, meter for the brightest part of the scene then lock it before doing the sweep to avoid excessive blown highlights. Manual focus is a good idea too.
I think if your camera’s good enough, and your eye’s good enough, plugging it into Microsoft ICE to sort out the stitching gives great results.
These fall down on the camera (just a blackberry) so wouldn’t be good enough to blow up too big, but I think they came out pretty well, considering. ( still kicking myself I didn’t take a proper camera!) Some banding on the 1st one, but a short while in photoshop would sort those out. clicky for bigger.
Edit, plus what jad said about controlling exposure and focus throughout.
It’s not that important to do the pivoting thing. I’ve never done it and got decent enough panoramas. With a compact as well as a SLR. Didn’t even use a tripod here:
You can get around that with a compact. All cameras I’ve used set the focus and exposure when you press the shutter half way down. So you can point at the middle of your panorama, half press the shutter, then move to the far side, press it all the way down to take the picture, then as long as you keep it half way down between pics it’ll keep the same exposure.
nedrapier – Is that St Kilda? You just took the camera phone to St Kilda? Haven’y made it out there yet but its definitely on the to do list. Great pictures regardless.
You only need a nodal slide if you have objects close to the camera, using one avoids parallax errors.
for landscapes with no objects in the foreground like the examples above you can get away without one.
TP, yup, I know! Totally daft. I was there on a work trip, and slightly surplus to requirements, so I didn’t want to act like a total tourist, taking photos all the time. I did anyway, though, they’re just not very good! 2nd one is Plockton.
I do find it much easier to use RAW files from the camera so i can sort out consistent white balance at home. I also correct exposre and lift shadows aetc. before stitching
Hugin is good as well but less good at the stitching. It has many more out puts
I now often start in ICE out put as a cylinder then put it into Hugin. This gives things like this
Sony TX5 compact tough camera auto panorama setting handheld on a mtb ride at Thassos. Its cheating i guess but im not really a fan of panorama pictures, that said i like some of the above. Dunno if the quality is good enough or not for full size, its had a small edit to adjust the colours so not washed out, theres some imperfections but not bad really.
Great pictures guys. I’m feeling inspired and lucky to be living in Scotland. Are sony the only ones to do it in camera. I assume the image can be tweaked on the computer if needed.
I always tended towards normal ratios but I now find myself living on the edge of the Cairngorms and I think the landscape would really lend itself to the wider aspect.
Thanks for this thread and the pointer to ICE
just grabbed the camera on auto and held in portrait sat on a swivel chair and clicked
popped it into ICE and bingo
TP, I’ve just bought a Lumix LX7 which does that. Only tried it once on a very bright, low sun winter’s day and it didn’t really work. Not surprised, though! I expect the Sony cleverness would have struggled as well. And me trying to cobble something together manually with enough range.
I’m on a Mac. I think that counts ICE out? Whatever I use needs to be idiot friendly too. While I can take a picture occasionally my computing skills could be worked on.
Nedrapier – easiest is to just crop and rotate to get a horizontal horizon – I do it in Lightroom but any image processing software will be able to do it.
Some of mine:
But what I really do them for is for virtual reality panoramas like this:
And remember to lock your exposure somewhere around the middle of the whole scene’s lighting, and focus on your subject and not re-focus/re-meter each shot
Lots to be going on with but can I also throw Autostitch into the mix? It’s free and incredibly good. I use it for professional panos for visual impact assessments.
You do need to spend an hour playing with the parameters to get a decent sized image out of it, but the stitching is better than anything else I’ve tried.
Right then, I’ve got some software and will take some pictures this weekend with the wife’s camera. If the results are any good I might even post one up here. The bar has been set high though…
