So, I moved into a rented house which is ok but quality of workmanship does not suggest a man who takes pride in his work.
After a few weeks there were some marks on the hallway wall from me scraping it with my workbag, trying to squeeze past my bikes.
Shouldn;t be a problem I thought, I can just wipe the wall down. Tried that with a damp cloth and found paint all over the cloth – not the best paint job in the world.
Found the tin of paint in the understairs cupboard and painted over the marked areas – should be fine. Except, as per the instructions on the tin, I didn’t water the paint down.
Turns out however, where I’ve painted, there’s loads more paint than the surrounding walls – you can see it clearly and it’s also much smoother when you run your hand over it.
I came to the conclusion the paint used by the landlord’s handyman had more than a little bit of water in and have proceeded to paint the offending patches with water to try and thin it out. But after about 10 applications it’s still showing – albeit with some improvement. Noticeably the water beads on the bits I’ve painted but doesn’t on the surrounding walls so I’m coming to the conclusion he must have gone something like 50/50…
So what’s the best solution for sorting this – just wiping the patches I painted with a damp cloth to try and spread the paint over a wider area?
We’re talking about 4 small patches here. trying to repaint the whole area means a long hallway + stairwall and landing…
