just moving into a house and will need to freshen up most of the rooms in a ‘neutral natural hessian type stylee’
have used pads before and found them easy enough to use, no mess, rollers also easy enough but you always get the fine micro-splatter. so id have guessed pads. but, as they say, you never see a professional decorator using pads.
im guessing the pro’s will say rollers are better, and if so what do i invest in? gonna use water based paint as i seem to remember the last time i painted, pretty much everything i used had to be chucked away in the end cos i didnt clean it properly.
so….. whats my best options?
thanks
