Hi, this may be an idiotic question – I fitted some shimano deore brakes to my bike (ragley blue pig with rocckshox revelation forks, 26″ wheels) and have just changed the pads for the first time and it seems that about 5-6mm of the pads aren’t making contact with the rotor. Eyeballing the way the rotor is sitting within the caliper, it looks like there’s a similar amount of clearance, maybe 7-8mm, between the rotor and the lowest solid part of the caliper, i.e. much less than the 20mm that would suggest that I had completely the wrong size rotor/spacer setup.
The frame has universal brake mounts, as far as I know, and the spacers are the ones that came with the brakes, and as far as I can tell are fitted correctly. Any idea what I’m doing wrong?
