Viewing 5 posts - 1 through 5 (of 5 total)
  • Pace RC41 fighters
  • shindiggy
    Self service or send them off? Leaking seals on the air chamber side.
    wwaswas
    send them to Tim at Fork English – helpful bloke and good service.
    seanoc
    Self service in the first instance, send them off if you can’t sort it. They’re not particularly hard to service although I have never changed a seal on them. May just be a bit of grit.
    Clamp fork upright, undo retaining bolts on lowers, stick a socket on and give a little clout with a rubber mallet, pop the lowers off, clean and grease the seals with some cristo lube or similar, change oil, bobs a good’un.
    Surely you’ve been doing this every 6 months or so anyway, the seal part at least?
    takisawa2
    As above.
    Good prices, basic service £29 IIRC. Seals extra but a whole rebuild with bushes cost was less than a service at Mojo etc.
    shindiggy
    Was thinking of sending them to Pace, £79 inc return carriage, only £4 more than Tim of Fork English.
The topic ‘Pace RC41 fighters’ is closed to new replies.
