Hello,
I changed the oil in my DT Swiss XCM 130s, and gave the air side slider a clean and oiled, and put a little oil in too.
Put back together, now the fork when compressed makes a knocking noise from the left (air) leg, and the fork bumps back up the travel… then only extends to about 100 / 110mm.
What is going on?
There is a black plastic cup which sits on the slider, which when moved up and down sticks on the slider – as if there is a seal which is swollen and sticking… but i've fully cleaned and oil, cleaned and teflon greased… still the same issue.
Has anyone got any ideas? Emailled Pace, but no reply – haven't had the chance to give them a call in working hours.
Thanks for any help,
Ricks
