Bearing life is excellent – mine spent about three years being thrashed regularly around the Peak and only needed the bearings changed once – the caps over then are o-ring sealed and they seem to work. I went through a fair number of shock mounts over the same period of time though. Both easily user serviced btw.
The original DT Swiss shock works well too, but I blew mine up twice. It now runs a Pushed RP23 with one of the air chamber volume reducer spacer things and that’s decent too, but it really did need the spacer. I run a Pike on mine with a 2? slackset thing.
The only cable/hose issue I’ve had was with the rear brake hose which runs under the BB and over a sharp edge at the base of the swing-arm. Got smacked by a rock which cut it in half. I now have some convoluted hose around the brake line to protect it.
I think basically it’s a really good all-round trail bike. I only changed the headset out of curiosity and because I got used to Ragley steering angles and kept riding off the edge of the trail every time I changed bikes.
I’ve also had decent service and advice from Pace when I needed it, though I know Pace gets hammered on here mostly over warranty claims on their hardtail frames.
I like mine, but it doesn’t get ridden that much at the moment.
