Viewing 10 posts - 1 through 10 (of 10 total)
  • Outlook problems
  • sealogger
    Aaaarrrggh
    Just sat down this morning to find all my ‘automatic’ email address’s (ie when you tap in lead letter they appear on scroll down menu)have vanished from outlook ??
    Can I retrieve them ? Where have they gone?
    xiphon
    Did anything else seem strange when you logged on?
    CaptainMainwaring
    I’ve had this in the past. Don’t know why it happens – it just does. It’s a pain but you just have to rebuild the list by selecting the names from your address book
    matt_outandabout
    Outlook
    There is your problem right there.
    muddy_bum
    To turn on automatic completion of e-mail addresses
    1.On the Tools menu, click Options.
    2.Click E-mail Options, and then click Advanced E-mail Options.
    3.Under When sending a message, tick the Suggest names while completing To, Cc, and Bcc fields check box.
    also check
    Nirsoft NK2 edit
    Cougar
    You can force a manual completion with control-K (I actually prefer this behaviour to the autocomplete, YMMV).
    If ^K fails, it’s not got your address book set as a contact source (set under Tools / Accounts usually). Probably worth a reboot before changing anything just to rule out temporary insanity.
    dh
    Sounds like your nickname file has disappeared (or you have logged in with a temporary profile). Have a search/root about in for C:\Docs & Settings\<username>\Application Data\Microsoft\Outlook for a file name nk2 and copy that over.
    sealogger
    Thanks All
    I’ve just logged back in tonight, and the ‘new’ autocomplete list that I had made only this morning has now vanished. So it mustn’t be saving any at all ??
    Muddy bum – I can’t find the tools menu (I am on office 2010)
    Cheers N
    jimmy
    Its called Recent Contacts in [b]Lotus Notes[/b][/u].
    wallop
    I had this problem recently. Weirdly, they all came back the next day. Someone in my office suggested it was because my inbox was full (can’t understand that though).
The topic ‘Outlook problems’ is closed to new replies.
