The price of Shimano chainrings seems to have skyrocketed so I've been keeping an eye out on ebay. I have an XT M752 Octalink chainset with a standard 4 arm, 104mm BCD (outer ring) setup. I picked up a 44tooth Deore M510 ring cheaply on the 'bay as a spare for when the XT one goes (I've already got Deore M510 steel granny and middle rings fitted).
It's just arrived and what I didn't realise is that it's a version that's been drilled to take a chainguard and as such doesn't have a chain drop pin (the pin that usually protrudes from the outer ring behind the crank to catch a dropped chain).
So, do I actually need a chain drop pin for safety's sake or can I get away without one. I'm assuming that it's hardly critical and I don't recall ever having lost a chain over the outer ring anyway, I only ever seem to drop chains over the granny ring (and then only rarely). I'm not sure what the benefit of catching a chain on the pin rather than letting it drop onto the axle (which is where it usually ends up if it drops over the granny ring) but I suppose if you're shifting up to the outer ring you're liable to be going faster than you would losing it off the granny, so maybe it is there for a reason. I don't want to put a chainguard on!
I suppose that the other question is where 4 or 5 drillings through the ring will weaken it at all, I don't really mind them being there for the price I paid as long as the ring's sound.
