• This topic has 4 replies, 3 voices, and was last updated 14 years ago by Bez.
Viewing 5 posts - 1 through 5 (of 5 total)
  • Outer chainring, what does 18mm arm width mean?
  • PJay
    I haven’t really likes the Middleburn outer ring I bought for my Shimano XT chainset so I’ve been looking at other options. TA seem to do some nice rings and do a 44tooth, 4 arm outer compact ring with a 104 PCD/BCD all of which match the my current Shimano outer ring. However, they also mention an 18mm arm width (I haven’t seen this with other rings), what does this refer to and as it’s a 4 arm ring with a 104mm BCD is it safe to assume that it’ll fit my Shimano chainset?
    Onzadog
    tick (as I’m not happy with Middleburn either)
    RealMan
    arm widths come in either 18mm or 23mm I think, and is the width of the arm where it connects to the chainring. If you get one that is the wrong size, it will still work fine (I think), but it will look weird.
    Bez
    Well you say yourself, “it’s a 4 arm ring” – the arm is the bit that there’s four of, and the arm with is how wide those bits are. The implications are purely aesthetic.
    Bez
    Me type slow.
The topic ‘Outer chainring, what does 18mm arm width mean?’ is closed to new replies.
