Usually, with resettable circuit breakers, the offending circuit will be identified by the tripped out breaker.
If it’s not an individual circuit, but the RCB (Residual Current Breaker) on the end of the row of CB’s, then you have an earth leakage on any circuit on the RCB.
The RCB itself could be defective, but you’ll need a certified sparks to sort this out.
Try unplugging everything on each circuit one by one to prove it’s not just a defective appliance you are using (very possible).
This could take time! Make a note of each change.
If you get no trip out when a particular circuit has no loads, start to add each appliance back on until you find the offending appliance. As I said, it will take days because you’ll need to wait up to your experienced maximum of 5-6 hrs.
Of course, if the tripping out continues regardless of loads, it could be the RCB, or a fault anywhere in the house’s wiring that is attached and protected by this RCB breaker.
It would be an expensive callout if all that was causing this is an appliance, but if it isn’t, you DO need a qualified electrician.
BE VERY CAREFUL!
