there’s only one cure for toothache.. A dentist.
I’ve recently had dental issues and the following worked a bit for me..
Whisky.. Very Temporary relief..
Milk.. Slightly less temporary relief..
Paracetamol and ibuprofen alternated every 2 hours worked best.. (make sure there’s a 4 hour gap inbetween each drug though!!)
So.. Para, 2hours later ibu, 2 hours after Ibu more para etc
Codeine helps a bit but it’s more ooo I’m floatee and high so I’ve forgotten about the pain.. rather than actual pain relief..
I’ve used clove oil before and it does work to a degree
But i found it utterly evil stuff and it basically melted the inside of my mouth.. Big chunks of.skin coming off.my cheek.and gums!!
Try leaving some on a bit of plastic you don’t need and see what it does to it.. (spilt some on an old phone and it pretty much destroyed the plastic case overnight!!)
The only permanent cure will be dental work.. And / or antibiotics..
Get in as soon as you can and to hell with the cost.. Teeth don’t ever get better on their own permanantly.. And dental pain can get utterly utterly Horrendous if left untreated professionally.
