I wonder if anyone could suggest things to try to get an SUSE 11.4 machine to see the printer (HP colour laserjet) on our network.
Machine will have a 130.88.x.x IP, printer has a 10.99.x.x IP
Windows machines in the same office can connect to the printer and all works fine.
Linux machine can't see it, have tried CUPS, HPLIP setup wizard and YASTs own printer setup. Have turned off firewall to check that it's not that causing a problem. I can't even ping the IP address of the printer for some reason (Can ping other IPs. Windows machines can ping the printer fine too)
