What degree are you studying for? That will depend on how ‘deep’ you need to go.
I would say you can learn the basics of ECGs from ECG made easy, but it’ll take a long time of looking at lots before you get ‘good’ at them.
ABGs – well, I can’t comment on the above link as it does look clear, but I haven’t gone into great detail in it. I find, again, that exposure to lots of them is a good learning tool. Another good resource is the ‘info’ above the ABG machine as that is a good, quick, simple guide…
The thing for ABGs is to remember – it’s not just the O2 level you’re interested in!
I look at it as:
1)pH – high, low, normal…?
2)PaCO2 – is THAT high, low, normal, and is THAT causing the pH abnormality? If so, it’s a respiratory issue.
3)Bicarb/BEx – is THAT high, low, normal, and is THAT causing the pH abnormality..etc etc..
4)Is one COMPENSATING for the other? This usually means a CHRONIC state. If not, it’s usually an ACUTE state.
5)PaO2 – are they hypoxic. Low O2, low CO2 = type 1 failure. Low O2, high/normal CO2 = type 2 failure….
That’s a basic – go online and see if there’s a resource of lots of results that you can interpret Have fun.
DrP
